FINALLY took delivery of my new B6 S4 Avant this week. A few questions...
#11
Banned
in turning radius between the inside and outside tires. I aslo have the same condition on both my AWD S4 and AWD Mountainer. Get used top it because there is nothing to fix . What you are hearing is the friction between the tires and the road surface due to Quattro system not allowing one of the wheels to turn at a different rate at slow speed.
#12
...as I said, "for the most part"... ;-)
#13
How can that be? Audi's diffs are "open" I believe. There should not be binding, "crabbing".
#14
First, I have zero binding on my S4. On the way into the office on this morn, I did a couple tight turns back and forth in my culdesac and there is zero binding on my S4. And I know what binding is, because I had it on my Touareg due to an increasingly bad stepper. The function of a stepper motor is to effectively eliminate the binding that would occur due to the differing wheel speeds. I have zero binding on my AWD Land Cruiser as well.
If you can actually notice the binding you've got something wrong, and if it's bad you're in for faster wear on your tires and your drivetrain.
#15
Banned
They behave exactly the same. Same scrubbing of tires as I make a slow left hand turn into my garage. It is definitely the tires scrubbing against the asphalt. I have heard it from outside the car. BTW, I doesn't happen when the driveway is wet.
#16
Thank you. 2nd that.
#17
And both are Torsen too.
Czechm8te
Want To Buy - Archive (NO NEW POSTS HERE)
12-03-2016 09:08 AM
calberto
10-17-2006 04:38 PM
tempests4
04-18-2005 06:16 AM
Scott W
09-06-2003 09:58 AM
