Fog Light HELP!
2004 S4,
The info center flashed a little fog lght and gave me a beep. Once it got dark I checked the lights and yes the fog lights were not on. So I thought I had burnt out fog lights to replace. Since both are out I thought I would check the fuse 1st. Opened up the fuse panel, the diagram says it should be a 15 amp fuse in slot number 19. Unfortunately there is no fuse in slot 19 and no connections within the slot for a fuse. Manual says same location.
Does anyone know what fuse is for the fog lights?
Next step was to check the bulbs. Opened up the 1st one and the bulb looks brand new.
Please help! I don't know what fuse or issue I could be having.
Thanks
Thanks
If the dealer performs this work, will the fog lights then work?
This car is a used CPO vehicle, should this have been done prior to the certification?
Does anyone know what fuse is for the front fog lights on a 2004 S4? I have the TSB thanks to TonyG3, but I am not sure if this will solve why my fog lights don't work.
Thanks for the help
Thanks for the help
bronxnativ
06-27-2010 04:31 PM
mAgnum8
09-19-2008 03:05 PM
Asicks2.7T
09-25-2006 06:01 AM
A4suited
09-15-2005 12:05 AM
