S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
H&R vs PSS9 vs Stasis SL. Why/Why not?
Old 02-15-2009, 06:17 AM
  #21
S4Buckeye's Avatar
Default Cool, thank you for the help.
I will e-mail him and see what he says, but the KW V3 looks like the way I will go at this point.
Old 02-15-2009, 06:23 AM
  #22
Jet Jockey/A4 Pilot's Avatar
I did not mean you were buying them but I'm surprised no one on AZ challenged it.
Old 02-15-2009, 06:30 AM
  #23
Default One more thing on the KWs. I'm not 100% sure if you can adjust the shocks...
Without having to remove them from the car.
Please check into this because if some of the adjustments are only available by removing the shock from its mounting point then that's a major PITA.
Again knowing how good the MS kit is with the Ohlins I personally would lean towards them but this is speculation on my part.
Bob is the one you need to contact.
Old 02-15-2009, 06:35 AM
  #24
S4Buckeye's Avatar
I was as well.
Old 02-15-2009, 06:50 AM
  #25
S4Buckeye's Avatar
Default Yes, non-removal adjustability is critical!
This looks somewhat promising, but...<ul><li><a href="http://www.kw-gmbh.de/kw_upload/Einbau/ea68577013.pdf">KW Clicky (scroll down for english)</a></li></ul>
Old 02-15-2009, 07:39 AM
  #26
Default If there is a problem it might be with the top adjustment on the front shocks...
You will need to confirm this with them.
I heard (as with other kits) you might have to "drill a hole" somewhere in the top of the strut housing to get the tool in for the adjustments.
See this thread on the B7 RS4 forum...<ul><li><a href="https://forums.audiworld.com/rs4b7/msgs/113662.phtml">https://forums.audiworld.com/rs4b7/msgs/113662.phtml</a</li></ul>
Old 02-15-2009, 08:02 AM
  #27
S4Buckeye's Avatar
That is reason enough for the extra $1k for the MS
Old 02-15-2009, 03:52 PM
  #28
AudiWorld Expert
S4iowa's Avatar
Default Thanks! So it looks like H&R linear springs still on the Bilstein shocks.
Wonder who makes the H&amp;R shocks? Koni?
Old 02-16-2009, 11:30 AM
  #29
S4Buckeye's Avatar
According to Jason at STaSIS, TS will work on B6
Old 02-16-2009, 11:34 AM
  #30
AudiWorld Expert
S4iowa's Avatar
Not from a B5 chassis. It won't work.
Quick Reply: H&R vs PSS9 vs Stasis SL. Why/Why not?
