H Sport Sway Bar Set Up
What is the better setup to have for this car/sway bar? FRONT & BACK?
thanks in advance
P.s. the car would not be seeing the track. (say I say now
thanks in advance
H Sport set...F/R.
I bought the set, but first installed rear only. The car instantly went from understeer to almost perfectly neutral front to rear, with noticeable reduced roll. When I later installed the front, there was even less body roll, but now the car is back to slight understeer bias (better than stock for sure) but the steering also feels alot heavier. To be honest, I liked it best with rear only installed, and may change it back at some point. YMMD. But, at minimum, I suggest starting with a rear-only install and driving it for a week before you install the front. Then you will know what you are getting out of each.
