Had rough idle, flashing MIL driving tonight. Then it went away.
Here are the fault codes:
Tuesday,06,January,2009,18:28:57:30630
VCDS Version: Release 805.1
Address 01: Engine
Control Module Part Number: 8E0 910 560 G
Component and/or Version: 4.2L V8/5V G 0010
Software Coding: 0007711
Work Shop Code: WSC 63351
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16689 - Cylinder 5: Misfire Detected
P0305 - 001 - Upper Limit Exceeded
16692 - Cylinder 8: Misfire Detected
P0308 - 008 - Implausible Signal
16690 - Cylinder 6: Misfire Detected
P0306 - 001 - Upper Limit Exceeded
16691 - Cylinder 7: Misfire Detected
P0307 - 008 - Implausible Signal
16405 - Bank 2: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0021 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Any ideas? This happened to me once several months ago as well. Then, like now, it seemed to just go away after shutting the car down, resting a bit, and then starting it back up. Now there seems to be no problem (rough idle is gone, no misfires).
By the way, the flashing MIL stopped immediately after I started moving the car again after idling.
Why does this stuff only happen to me right before a track event? I don't think the car likes me very much. Sigh.
Address 01: Engine
6 Faults Found:
I sadly had a broken valve spring on the #5 cylinder. Had that side rebuilt and it has been running great since. However, I'm a bit concerned this is happening on the same side.
Like I said, this happened once before all this valve spring business. But that was just a one-time experience. At least until now. Dang.
As luck would have it I have an appointment at my dealer tomorrow anyway so I'll have them check it out. Since it seems to be running fine now, I'm sure they'll just clear the codes and tell me to bring it back if it happens again.
The engine was already out for warranty work on the head, so I just had them add on this job.
wants them to replace a cam adjuster on bank 2 given its history. The car is actually running great, but Audi is concerned it may not start eventually. Sigh...
By the time I'm done with this car it will be practically new!
(No, this doesn't discourage me one bit.)
