Help with this code please...
I posted this in the VAG forum as well. You guys here seem to be the sharpest. This is a friends 2004 A4 3.0. The CEL only clears momentarily. Once the car is started the code is already back, although there are no symptoms of any kind. I'm a novice at this and ANY help is appreciated. Is there anything else I can do with the VAG to assist in the diagnostic? Like I said, I'm a novice and I barely know what I am doing with this tool. Thank you.
Thursday,11,June,2009,16:05:05:19849
VCDS Version: Release 805.4
Data version: 20090602
Address 01: Engine
Control Module Part Number: 8E0 909 559 L
Component and/or Version: 3.0L V6/5V G 0020
Software Coding: 0016581
Work Shop Code: WSC 63351
1 Fault Found:
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - Implausible Signal
Readiness: 0110 1101
Address 01: Engine
1 Fault Found:
coocoomike
11-20-2002 08:18 PM
