S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
help!! dealer can't fix my b6 ...
Old 06-20-2008, 10:11 PM
  #11
hly
hly's Avatar
Default Unbelievable! Sorry to hear that. How can such a bunch of incompetent jerks be allowed at an Audi
dealership?
I hope your car will be fixed soon, and I hope someone at Audi of North America reads this.
Old 06-21-2008, 02:07 AM
  #12
New Member
Just Incredible B6S4's Avatar
Default Sorry to hear this. Call Audi customer relations. I had an issue resolved by doing this also
I am not saying this is the issue on your car. But I saw a fellow had kinda a similar issue with his A8. Basically the rev limits for the motor are much lower in limp mode situations or under certain situations like oil temp too hot or bad signal from the speed sensor or any other dependent input for safety.
In the end the A8 guy had a bad oil temp sending unit this was stopping the car from revving past 4000 from what i remember. Definitely look at it with the Vag. When it happens check for codes some time you will get lots of codes and no CEL
Definitely keep us posted
Old 06-21-2008, 04:56 AM
  #13
Jas0n's Avatar
i second that, but on a different note, your 996tt is sick nm
Old 06-21-2008, 05:03 AM
  #14
Jas0n's Avatar
its going into Danbury on Monday instead, Classic was booked through the week nm
Old 06-21-2008, 05:45 AM
  #15
The Mystro S4's Avatar
Call Audi. They helped me a few times with a jackazz dealer.
Old 06-21-2008, 06:39 AM
  #16
Jas0n's Avatar
Default update: a local shop scanned the cel code ...
I don't think it was a VAG specific tool, but nevertheless, I appreciate that they could even do it for me. He wasn't sure of the specific code, but it is spitting out two 02 sensor codes that show the left bank is running too lean. Does this help or should I find someone with a VAG-Com?
the problem wasn't apparent in the 3 miles I drove the car today, but I know that if I got it at all, it would reproduce itself again within 15 minutes.
Old 06-21-2008, 08:44 AM
  #17
AudiWorld Expert
nyet's Avatar
Default what are your long term fuel trims?
log the car. should be immediately obvious.
i'd guess fuel system - clogged injector, filter, or bad fuel pump.
Old 06-21-2008, 08:45 AM
  #18
AudiWorld Expert
nyet's Avatar
Default something that obvious should be trivial to log
i dont get why nobody here has suggested the obvious.
Old 06-21-2008, 08:47 AM
  #19
AudiWorld Expert
nyet's Avatar
Default 108 views, the only useful responses are "yell at your dealer"
wow. just wow.
Old 06-21-2008, 09:41 AM
  #20
Jas0n's Avatar
Default I though it might be injectors ...
and so did the service writer, but they were supposedly checked out and fine. as we're the coilpacks, though the car doesn't run rough per se - it just doesn't put out power.
i have always run 93, except one occurrence about 2 months ago where a gas station didn't have 93 and I needed gas badly; even then, it was $20 worth of 89, and I hardly think that could cause for concern.
could it be sparks plugs that have fouled up? they haven't been replaced yet.
Quick Reply: help!! dealer can't fix my b6 ...
