HELP!!! RNS-E PIN
#11
Then they can look up the PIN. Took a little over an hour because the RNS-E was in "safe" mode.
In my case, the PIN wasn't even close to what was written on the card.
#18
If you have any other helpful hints let me know? This thing was the best recomendation to do EVER Def a first mod for any new buyers!
I mounted the GPS in my glove compartment instead of under the speedo and I seem to be getting 4-8 Sats all the time so I might leave it there. It's a little slow at start-up to catch up when I start moving, is that common?
Other than that I am still learning all that I can!
#19
I put mine behind the cluster. The cluster is a PITA to get back on correctly, at least in my car. The two bolts at the bottom are really recessed deeply and I had trouble lining them up to the speed nuts. Not much room to work with. Regardless, I get 2-4 sats and sometimes 0. Annoying. I'll try the glovebox.
#20
When you start in the morning, it can take the GPS sometime to catch up with me, are you haveing a similar problem? I even took the anntenna out and was getting 8 Sats but it still didn't catch up. Anyway to fix that?
