S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
I finally got sucked in and installed an intake
Old 04-11-2007, 11:57 AM
Corrado79's Avatar
Default I finally got sucked in and installed an intake
Despite all of my incantations regarding the worthlessness of open-air intakes and how the best dollar-to-HP mod you can do is a K&N drop-in filter, I fell prey to the powers of the intake. After hearing A4tooS4's car sound so good with just an intake, I couldn't resist and ponied up for an Evolution Motorsports V-Flow intake.
I chose the EVOms, specifically, based on the design quality. Its heat shield is the best IMO of what's available, they use a K&N filter which I like, and it uses a venturi-type centrifugal intake opening that should assist the flow of air. Despite all of those features, I did not notice a significant power increase. If anything, there was a slight gain in the 4,000-5,500 RPM range.
Best of all though, is the sound. Combined with the Milltek Fullback Res, it now has a balanced, aggresive sound throughout (not just at the rear when I only had exhaust modifications). In addition to the increase balance is a much more refined sound that "screams" a little more than before. Overall, worth every penny just for the sound alone.
<img src="http://img73.imageshack.us/img73/3956/dsc01273cm9.jpg" />
<img src="http://img54.imageshack.us/img54/5784/dsc01271zu3.jpg" />
Note: the flex-fitting in the middle of my factory air scoop has shrunk for some reason. Accordingly, as you can see, the air scoop does not fit perfectly as it should (i.e. flush with the rubber molding on the fender). I will be replacing/fixing that piece shortly.<ul><li><a href="http://www.evoms.com/marketplace/viewproduct.asp?productid={689CE535-5D34-4620-8D43-350BEF2FA2F7}">http://www.evoms.com/marketplace/viewproduct.asp?productid={689CE535-5D34-4620-8D43-350BEF2FA2F7}</a</li></ul>
Old 04-11-2007, 12:10 PM
AreenS4's Avatar
did you know youre missing the right side engine bay cover or did you take it off?
Old 04-11-2007, 12:14 PM
Brooklyn's Avatar
Default what right side cover?
i've got an early '04 and the layout of my engine looks exactly the same as his. what am i missing?
Old 04-11-2007, 12:15 PM
Rob4.2's Avatar
Areen, FYI, the 05s don't have the right side covers.
JamieO's Avatar
Default congrats... you almost have your car set up just like my old one now!
I just picked up a '07 S4 this morning... now I get to start all over again!!
Sometimes I wonder what they hell I'm thinking.
Old 04-11-2007, 12:17 PM
Rob4.2's Avatar
Brooklyn, it's the cover that sits between the coolant and washer fluid tanks..
Old 04-11-2007, 12:18 PM
JamieO's Avatar
Default my first '04 had it, my 2nd one didn't...
<center><img src="http://pictureposter.audiworld.com/19469/9-01.jpg"></center><p>
Old 04-11-2007, 12:20 PM
Brooklyn's Avatar
Default hmm - doesn't look like i have it
<center><img src="http://k43.pbase.com/v3/04/513704/1/46669412.S417.jpg"></center><p>
Old 04-11-2007, 12:25 PM
Rob4.2's Avatar
shoot, i guess late 04 models don't have it, but TonyG3 has a late 04 and has one.
Old 04-11-2007, 12:26 PM
Corrado79's Avatar
Thx! Your B6 was pretty sweet so you can't fault me. And Congrats re: B7. Keepin' it real
Quick Reply: I finally got sucked in and installed an intake
