If you were to upgrade to a set of forged wheels/tires..what size and offset wheels would you get?
AudiWorld Expert
Looking to help a friend with some data gathering and a possible offering for the B7 S4. So, what is the most desirable upgrade:
18X8.5
18X9
19X8.5
19X9
19X9.5 (will this fit?)
Offsets?
Thanks guys.
18X8.5
18X9
19X8.5
19X9
Offsets?
Thanks guys.
but I'm not a huge fan of the stagger with AWD. Although the way Dr. Quattro has his looks good, just depends on the wheels and amount of offset. I went with a wider tire to change the look instead (245/35/R19).
It doesn't have different tire weights, you just input the weight of the wheels and the tires. The sheet will then add, subtract, and multiply, to tell you what kind of weight savings you are getting compared to stock.
I only used the PS2s in my Xcel sheet because those are the lightest I could find. Tirerack.com has the weight of the tire when you click on 'spec.' remember the tire weight is different for each tire size.
It's just plug and play from there. I'd be happy to email it to you. Just email me.
