installed h-sport rear sway bar
install took about 40 minutes to do by myself. not a very complicated install. set the bar to the more aggressive setting. i can definately feel a difference in handling. i would recommend the bar without hesitation.
front 35mm bar going on sometime this week, maybe tonight if the red sox game gets rained out.
Congrats on doing the install yourself. Now that I've done one with someone's help I might be able to do one on my own but definately not if it was my first time.
AudiWorld Expert
Oh, and I forgot to swing by with the tools. Sorry. I'll try to swing by sometime this week (and scope out the new S4!).
Are you going to install the front as well? Just be aware that on Dave's car, the bar did somewhat interfere with the belly pan. It was hard to line up the two plugs in the fender liners because the H-sport sits a bit lower than the stock sway in front.
If you need a hand with the front, let me know. I'll be happy to help!
i had the same problem with the belly pan on my A4. eventually the belly pan wore down and made a big hole the size of the bar. i figure the same will happen on the S4 once it gets suspension :-/
i will def let know know if i need help. thanks!
