Laser Veil
ie the closer you get to the laser gun and it will penetrate the spray... it definitely won't jam to gun...
so id use it in conjunction with a laser jammer for sure though
Accepted, but here in the UK laser Jammers are all illegal, however laser detectors are still legal, so I was just interested to know if it does give you a few seconds to respond to the alarm.
the veil spray won't give you an alarm obviously and the detector is no where near a 100% lock to pickup laser targeted at your headlights...
so yes it will give you a couple of seconds for sure while its scrambling the laser from distance... but more than likely your detector won't go off anyway
it is no substitute for a laser jammer. If you live in one of the few states (like CA) that outlaw laser jammers, it's your only legal option right now. The tests in this link I posted show that Veil does help quite a bit in reducing the effective distance of the laser guns, but it's still up to you to SEE where the laser is coming from and slow down before it's too late.
What I'm wondering is if the coating is noticeable, or not. Is it totally clear, or does it look like you painted your headlights?<ul><li><a href="http://www.radarbusters.com/support/speedlabs-2005/veil.asp">http://www.radarbusters.com/support/speedlabs-2005/veil.asp</a</li></ul>
its almost useless by itself...
if you don't have laser jammers you stand such limited odds of detecting laser with a detector that once the cop gets punch through on the veil you will still probably have clue he even got you
The V1 has the best laser detection capabilities by far, but laser detection is useless if you don't have a jammer to go along with it. I guess I'm screwed living in CA, but fortunatelty laser guns are not the primary tool used by the CHP around these parts.
actually Bel has a new detector called the Bel Sti which is supposed to have the best Laser detection period...
next best would be the V1...
but truth of the matter is yeah if you detect laser 99% of the time its too late... 1% of the time you got stray laser bouncing off of something and got so lucky...
but most of the time the cop can hit your headlights/front grille and the detector flat out won't go off... that goes for V1 as well...
so like you i only have a detector and no jammers... its legal in my state, but i don't have the money... so its a slight false sense of security because i'm only half safe
That's probably the only thing saving me from getting my license suspended. It's just too damn easy to go from 60 to 110 in the blink of an eye in an S4, and I admit, I do it more often than I probably should.
