Local Audi Dealer offering to fill up tires with nitrogen.......
For $100.
They are saying it impoves handling and braking.
When did this go mainstream? I thought it was for racing?
nitrogen supposedly leaks out the tire slower than air so it will keep the tire pressure longer.
but to ask $100 for it is like McDonald's charging extra for ketchup.
Go to www.nitrofill.com to find the closest filling station to you and get detials on the product.<ul><li><a href="http://www.nitrofill.com">http://www.nitrofill.com</a</li></ul>
I got my tires/nitrogen from Costco, but they're incompetent. They damaged my car when attempting to lift it in order to replace the tires. Plus, I like to run a certain pressure in my tires (namely what is posted on the door), yet they are not willing to fill it up properly. They will only fill it within +5 psi of the door emblem when the tires are hot, although it requires +7-9 psi when hot in order to get the tires to the correct psi when cold. Personally, I will not deal with them again.
Costco's costumer service is top notch.
For the record, my local Costco tire guys are fantastic and true car enthusiast.
I thought the only reason to use nitrogen was because a molecule of nitrogen was bigger than oxygen and it will not seep out of the tire as fast so your tire pressure is more stable. Im I wrong?
