MachtigWes: what setup did you use for your harnesses?
Earlier posts have talked about the mods needed at the outside seat connection of the belt to the car. I have saved those, but if I'm right, yours might be the most recent install that's been posted.
Or is anything new out there that properly adapts an off-the-shelf harness, like Schrott's Ralleye 4, to our cars.
TIA
TIA
It uses the factory seat belt receptacles for half of the connections.
In the rear, the inside belt uses the factory receptacle. The outside belt will use a quick-release that is mounted under the seat using the factory seat belt mount.
The front belt (lap belt): inside uses the factory receptacle, the outside uses the shoulder belt.
<a href="http://b6s4.com/picroster/thumbnails.php?album=28">Some pics</a>
It will attach to the portion that comes up from the floor, not the portion from the retractor.
I then place the webbing inside the mount on the bottom of the seat. Hard to explain...let me see if I can find a pic of it.
beachcomber
14
07-26-2021 05:08 AM
uble1234
14
10-23-2020 08:07 PM
