My Coolant Temperature Sensor has gone bad. Can someone post the Bentley Manual
exploded view to show me where it is located? I tried searching, and someone said it's a 15 minute job, but someone else said it's in the back of the engine. That doesn't sound like a 15 minute job to me.
http://www.germanautoparts.com/Audi/...ectrical/181/3
Also, here are my codes. Has anyone else that had the coolant temp sensor go bad gotten the catalyst efficiency codes?
VAG-COM Version: Release 303.1
Chassis Type: 8E - B6 Audi A4
Scan: 01,02,03,08,09,15,16,17,36,37,45,46,55,56
Address 01 -------------------------------------------------------
Controller: 8E0 910 560 A
Component: 4.2L V8/5V G 0020
Coding: 0007711
Shop #: WSC 65728
5 Faults Found:
19497 - Powertrain Databus Implausible Engine Temp. Message from Inst. Panel
P3041 - 004 - No Signal/Communication
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 001 - Upper Limit Exceeded - Intermittent
16588 - Injector: Cylinder 4 (N33): Circuit Malfunction
P0204 - 004 - No Signal/Communication - Intermittent
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded - Intermittent
16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
P0431 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04595
Shop #: WSC 06435
0 Faults Found:
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
0 Faults Found:
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
0 Faults Found:
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 63351
0 Faults Found:
Address 17 -------------------------------------------------------
Controller: 8E0 920 981 G
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01229
Shop #: WSC 08312
WAUPL68E84A164795 AUZ6Z0C0388832
1 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to B+
Address 36 -------------------------------------------------------
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
0 Faults Found:
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 11848
Shop #: WSC 63351
0 Faults Found:
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
0 Faults Found:
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 H
Component: symphony II NP2 0410
Coding: 01000
Shop #: WSC 73472
0 Faults Found:
Coding: 0007711
Shop #: WSC 65728
5 Faults Found:
Coding: 04595
Shop #: WSC 06435
0 Faults Found:
Coding: 00000
Shop #: WSC 63351
0 Faults Found:
Coding: 01013
Shop #: WSC 63351
0 Faults Found:
Coding: 01041
Shop #: WSC 63351
0 Faults Found:
Coding: 01229
Shop #: WSC 08312
1 Faults Found:
Coding: 00002
Shop #: WSC 63351
0 Faults Found:
Coding: 11848
Shop #: WSC 63351
0 Faults Found:
Coding: 00060
Shop #: WSC 63351
0 Faults Found:
Coding: 01000
Shop #: WSC 73472
0 Faults Found:
9552T500
09-08-2015 05:41 AM
CPLYONS
09-07-2015 07:19 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
