NE 1 use nitrogen in their tires, if so where is a common place where i can go to get some put......
Maintains steady air pressure
Less tire pressure maintenance
Less fuel consumption
Better vehicle performance
More tire miles
Runs cooler
Less expansion in varying temperatures
More tire miles
Non combustible
Less tire failures
No Oxygen / Moisture
No oxidation - slows tire carcass aging
No corrosion - damaging metal rust or aluminum oxide
Nitrogen has been used to inflate tires for many years by the airline industry, military aircraft, space shuttles and shuttle transports, NASCAR, Indy 500, Formula One, Tour de France, mining and earthmoving equipment. In fact, the new monorail in Las Vegas will run on nitrogen inflated tires.
More tire miles
Runs cooler
More tire miles
Non combustible
Less tire failures
