OK update on my problem with my car. See several posts down for the 1st thread. So, I charge the..
battery, I start the car... It start fine, but once again... the headlights, interior lights, door locks, windows and several other things don;t work. The battery is fully charged, so it's not a battery or latenator issue. I found out that the light under the dash stays on (hence the battery died). So it's looks like the dead battery issue is a symptom not the cause 8-(.
my problem if i remember correctly was fuse #21( ? ) kept blowing due to a bad mirror motor. which in turn didnt let me lock doors, roll up or down windows, etc......
happens cause if you just lock your side with key passenger side wont lock. you have to open pass. door romove a black plastic clip from side of door by lock and stick the key in there to lock . then once you close door its locked. you can reopen from inside. kind of gheeeto but it works....
vaix49
14
09-05-2006 02:37 AM
