OMGHI2NOCAR (whistle noise update)
Nov 19. That's the earliest the seals will get here from Germany for the engine. The tech wrote:
"The block is 2 pieces. The upper part holds the crank shaft and cylinders. The lower half which contains the lower crank shaft bearings. Between these 2 mateing surfaces there is a silicone bead and 3 different o ring seals. One of the o ring seals on the left side on the engine is seeping coolant. "
So now I get to wait another three weeks.
At least they are giving me a Volvo S80 until then at no charge.<ul><li><a href="https://forums.audiworld.com/s4b6/msgs/154733.phtml">Prior Update</a></li></ul>
Not a typo at all... absolutely intentional.
I find that most Vulva drivers are slow, dim-witted mouth-breaters who don't know how to drive, so they buy a car marketed as a "safe" car to save themselves. It's the minivan for the upscale soccer mom!
You could also look at it this way-- my spelling of the name is more appropriate, since there's usually a d|ck inside...
-JPC
-JPC
John Elway
02-14-2016 11:01 AM
AudiSport4000
02-16-2002 06:07 AM
