Question about legal issues for aftermarket cats.
I was going to have a local exhaust store that does great work to make me a custom aftermarket downpipes for my car and they told me that they couldn't do anything to it since epa states that they can only change the cat if it is damaged or after 50k miles. Yes I know there are things that are test pipes that totally replaces the cat on A4's but these downpipes for the S4 are suppose to be 50 state legal. So i guess i'm wondering how can we really use the labree and milltek downpipes?
I did a little research on epa's website and got this.
(6) When can I install an aftermarket converter?
Generally, there are only 3 situations when you can install an aftermarket converter.
They are:
(1) if the converter is missing from the vehicle when brought in for exhaust
system repair; or
(2) if a State or local inspection program has determined the existing converter
has been lead poisoned, damaged, or otherwise needs replacement; or
(3) if the vehicle is more than 5 years old or has more than 50,000 miles*
(8 years/80,000 miles for 1995 and newer vehicles) and a legitimate need for
replacement has been established and appropriately documented (e.g., a
plugged converter or unrepairable exhaust leaks).
Any other converter replacement must be with a 'certified' or new original equipment (OE)
or equivalent converter.
Aftermarket converters subject to the enforcement policy requirements cannot be used for
replacement if:
(1) the existing converter is present and functioning properly; or
(2) the replacement is under recall or warranty; or
(3) the vehicle is returning from overseas use
They are:
system repair; or
replacement if:
Sting operations to ensure that we weren't selling used cat's to people. I had aftermarket cats on a Supra at the time and the gist I got from the inspector was that aftermarket cats were discouraged but the EPA didn't care provided the car still passed emissions tests
only". Tehcnically, you can be fined for using any of these products on public roadways.
audiquattroduo
06-21-2008 05:46 PM
Reggie
10-27-2004 06:56 PM
Mike'9390CS
08-12-2002 04:28 PM
