Question for H-Sport RS4 rear sway bar users
I just bought an H-sport sway set with the RS4 rear bar. After seeing the massive bar, I am not worried about the wimpy stock end links being ripped apart. Has anyone had problems with their stock sway links on the bigger rs4 h-sport bar?
I saw two different people break the stock links at the track with the regular H-sport kit
The people I saw break the stock link also had coil overs. I've had the S4 (not RS4) sways on for 20k miles and over 20 track days with no issues but I also have a stock suspension. Make sure to use plenty of lock-tite on the bolts (front and rear).
I have had the HSport RS4 29mm bar for 15K miles and a track day at mid ohio with no problems...
i've seen alot of screws pop out on any setup that isnt properly torqued but never had the problem with any of the three sets of HSports i've used.
Yes, proper install, proper torque and Loctite Blue medium thread locker on 'cleaned' threads.
Due to IMproper install, one of the bolts broke off...
Install is pretty straightforward, you must have weight on the wheels, torque, as well as use loctite.
I didn't have weight on the wheels, was very difficult getting the bolts in. After the bolt broke, I did it properly, was much easier! Note, just the bolt broke, end links were fine.
Massive? It's only 5mm larger in dia. than the S4 rear sway.The monster is the...
...Hsport front bar...it's heavy too, compared to the oe bar.
Properly installed, torqued and lock-tited, the system is trouble free and invisible to the ride.
Enjoy, good luck.
Enjoy, good luck.
markbradford
11-22-2007 09:40 PM
Crs-KWaf
06-15-2007 03:25 PM
RS4 SE
RS4 (B7 Platform) Discussion
13
05-01-2007 08:30 PM
