S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Removed Audi Telematics (On-star) and replaced with Audi Bluetooth module for RNS-E (edit)
Old 03-10-2006, 06:06 PM
ESFO's Avatar
Default Removed Audi Telematics (On-star) and replaced with Audi Bluetooth module for RNS-E (edit)
Some of you might remember that I added the RNS-E nav to my car a couple months ago. Well, on Wednesday, 'Audis or VWs 4Life' and myself removed the Audi On-star brain from my car and replaced it with Audi's bluetooth module. The RNS-E has built in phone capability and since I'm not using and won't be using On-star, I got rid of it. The bluetooth module plugs in right where the telematics box did and it's all hidden away beneath the passenger floor. It was a real pain to do, with wresting with the trim, carpeting, insulation, and unbolting the passenger seat. But in the end, well worth it. I could have installed it another way that would have foregone this wrestling match, but I would have just traded it for a different method that would have required more wiring and routing of such... no thanks. With this method, you simply remove the telematics box, remove ten pins from the 42 pin connector and insert those ten pins into a new 54 pin connector. Plug it into the bluetooth module and close it all up. Then vag the car to tell it that On-star is gone and bluetooth is in the house and bam, your done. My Sonyericsson K750i, which is not available here in the states needed to have it's software updated to work flawlessly, but it does now. A list of supported phones can be found here, <a href="http://www.navplus.us/forum/viewtopic.php?t=1196"> Click. </a>
You can have handsfree operation through aftermarket means and pay less, but nothing is as cool or well integrated as the factory setup.
Here are some pics:
<b>REMOVAL OF TRIM AND CARPET LIFT</b>
<img src="http://home.comcast.net/~v8s4/carpet.jpg">
<b>AUDI'S BLACK BOX, HOME OF TELEMATICS</b> (ON-STAR)
<img src="http://home.comcast.net/~v8s4/blackbox.jpg">
<b>BLACK BOX OPENED</b>
<img src="http://home.comcast.net/~v8s4/bbinternal.jpg">
<b>TELEMATICS MODULE</b>
<img src="http://home.comcast.net/~v8s4/telematics.jpg">
<b>42 PIN CONNECTOR</b> (removed from telematics module) Note that the two accompanying plugs are not needed for the bluetooth box and were simply taped to the leading wiring harness.
<img src="http://home.comcast.net/~v8s4/42pin2.jpg">
<b>REMOVAL OF PINS</b> (for insertion into 54 pin connector)
<img src="http://home.comcast.net/~v8s4/pinremove2.jpg">
<b>54 PIN CONNECTOR</b>
<img src="http://home.comcast.net/~v8s4/54pin.jpg">
(Thanks to NSX JR for pic)
<b>CONVERSION CHART</b>
<img src="http://home.comcast.net/~v8s4/Conversion.jpg">
(Thanks to AudiA4B6US for pic)
<b>BLUETOOTH MODULE</b>
<img src="http://home.comcast.net/~v8s4/BT2.jpg">
(Thanks to PROXUS for pic)
<b>ANTENNAE</b>
<img src="http://home.comcast.net/~v8s4/antennae.jpg">
Once you have this all done, use VAG-COM and re-code the car. Information on what to do can be found here, <a href="http://www.navplus.us/forum/viewtopic.php?t=1362"> Click. </a>
So we buttoned it back up and this is the result:
<img src="http://home.comcast.net/~v8s4/dial.jpg">
<img src="http://home.comcast.net/~v8s4/memory.jpg">
<img src="http://home.comcast.net/~v8s4/dialed.jpg">
<img src="http://home.comcast.net/~v8s4/Phonebook.jpg">
<img src="http://home.comcast.net/~v8s4/missed.jpg">
<img src="http://home.comcast.net/~v8s4/nightvision.jpg">
When I get into the car with my phone in my pocket I hear a little 'bong' that tells me that my phone and the car are communicating. Then if I get a call it automatically mutes the radio and I hear a ring. I have my phone set to answer by just saying "Answer" and it picks up and the callers voice comes over through the speakers. If I don't want the call I say "Busy" and it goes to voicemail. Dialing is pretty self explanitory just by looking at the pics.
Total cost for all parts necessary (from Audi):
Bluetooth Interface = $537.30 part#8P0-862-335-B
Antennae = $17.38 part#8P0-035-503-E
54 pin plug = $7.38 part#4E0-972-144
Be aware that you can buy a package from sellers on the navplus forum for similar costs. Also, for more indepth questions and answers, see the navplus forum. But I'll answer any questions I can here.
Lastly, many thanks to 'Audis or VWs 4Life' for your willing help on the effort.
Old 03-10-2006, 06:16 PM
Karrera4's Avatar
wow..that is awesome...nice work
Old 03-10-2006, 06:35 PM
Tim W.'s Avatar
That is just to cool! Great Job
Old 03-10-2006, 06:44 PM
RKA
AudiWorld Uber User
RKA's Avatar
That's cool! Nice job!!!
Old 03-10-2006, 06:58 PM
JDBlueAudiS4's Avatar
Default Rodney... You and Arpad did a great job...
keep up the good work. Whats the next project?
Old 03-10-2006, 08:12 PM
TXurS6's Avatar
I think your Nerd score just went up significantly
Old 03-11-2006, 05:53 AM
S4 in Margaritaville's Avatar
Default Great job, just getting ready to buy everything to do the same.
Do you ahve the pin outs from going from the 42 pin to 54 pin?
Anything else to do, or does it use the same onstar mic, etc.
Love the clean install...great job again!
Old 03-11-2006, 07:58 AM
ESFO's Avatar
Default Thanks... Regarding any extra work...
Absolutely nothing else to do. It uses the On-Star mic in the overhead light area. In fact, I purchased a microphone originally because I thought that I was going the other route with the install. So now I have a spare $162 mic.
Here's a link to the pinout conversion table:<ul><li><a href="http://www.navplus.us/forum/viewtopic.php?highlight=telematics&amp;t=1876">Tel ematics to Bluetooth</a></li></ul>
Old 03-11-2006, 07:59 AM
ESFO's Avatar
Default Next project? Well, riddle me this Batman...
What's the only way to get 750hp out of a 4.2L S4 engine?? ))
Old 03-11-2006, 11:58 AM
ruknd's Avatar
nice...what is the button next to your ESP?
Quick Reply: Removed Audi Telematics (On-star) and replaced with Audi Bluetooth module for RNS-E (edit)
