S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
So my gf drove home with her rear tires at near 10 psi...and now there's plenty of wooshing going on
Old 10-28-2005, 07:44 PM
Member
Blau Flash's Avatar
Default So my gf drove home with her rear tires at near 10 psi...and now there's plenty of wooshing going on
What do you guys think happened? Are the tires definetely out of round?, because there's a definete whaa whaa whaa noise happening past 60mph....
NO, not my car!
Old 10-28-2005, 08:12 PM
Member
Blau Flash's Avatar
Anyone, this is kinda dangerous....
Old 10-28-2005, 10:45 PM
Member
Quattrosaurus's Avatar
Default As easy as taking them to a tire shop, having them dismounted and inspected.
Ofcourse, you should NOT drive the car there. There could be some sidewall damage. Better safe than sorry.
That should answer all your questions.
Old 10-29-2005, 12:04 AM
AudiWorld Expert
Sia Bani's Avatar
Um, fill them with air.
Old 10-29-2005, 06:40 AM
Junior Member
Car Crazy's Avatar
Default Jack up the rear and spin the wheel (or take a wheel off)....
If you hear something rolling around inside the tire (like it is full of pebbles), it is trashed. This could account for what you are feeling. When one drives on a tire that low in pressure, the sidewall destroys itself from the inside. If you remove the tire from the wheel, you will see lots of shredded rubber from the sidewall. Whether or not 10psi is low enough to do this, I don't know. I'm sure it depends on tire construction, sidewall strength, and car weight.
Old 10-29-2005, 07:09 AM
New Member
gtaste's Avatar
Need to do your gf in the butt first as punishment for her
Member
Blau Flash's Avatar
the tire loses 8psi a day....this is rel bad.
Old 10-29-2005, 07:26 AM
Member
Blau Flash's Avatar
well at least it wasnt my car...
Old 10-29-2005, 09:08 AM
Audis or VWs 4Life's Avatar
Default Speaking of tire pressure everyone in northern climates check it up...
I did this morning was down to 36 up front and 34 in the rear, cranked it back up on 42 and 40.
Old 10-29-2005, 09:46 AM
Member
S4_Cinci (I S'edTFA)'s Avatar
Default At least 1 psi for every 10 deg F decrease in ambient air temp...
That is what you tires lose from summer to winter. Be sure to check those tires!
Quick Reply: So my gf drove home with her rear tires at near 10 psi...and now there's plenty of wooshing going on
