Step-by-Step RD Hardwiring to the Interior Auto Dimming/Compass Mirror
Thought you might be interested in another way of hardwiring the RD into an Audi with auto dimming/compass mirror. I tried this on 2003 A4, 2003 alloroad and 2004 allroad - works well.
Disclaimer - as usual, the poster of this thread is not responsible to any damage to your vehicle or radar detector. Please exercise common sense and use appropriate tools (including a voltmeter to make sure the polarity is correct).
Tools: Flat head medium size screwdriver, pliers, small scissors, a set of Radio Shack "Telephone Wire Tap Connectors" (part number 64-3081) and 5" of telephone wire with RJ45 jack on one end (this is for Valentine V1 or Escort Passport 7500 or 8500 - other models might require another connector on their end).
Time: 45 minutes if you have "two left hands", sooner if you are handy enough.
Misc. Notes: It is better to do this mod when it is daylight outside - you'll see things much easier.
1st step. Switch the ignition OFF! Unclip a plastic wiring cover protecting the wires coming from a headliner to the mirror (use the flat head screwdriver - pry on the passenger side first
2nd step. Remove the wire connector from the retainer and if you want more freedom of movement, disconnect it.
3rd step. Splice longitudinally the rubber conduit (tube) BELOW the connector (on the way to the mirror) as low as you can to free up 6 wires: yellow, green, brown, gray, black and white. White wire is switched +12 volt. Power comes on when you switch the ignition only. Black wire is a ground wire.
4th step. Using the "Telephone Wire Tap Connectors" - perfect fit for these wire diameters - connect the telephone cord to the wires as low as you can (this way you would be able to tuck them into the wider part of the mirror base later). Make sure the wires coming to the mirror are pushed all the way into the connector groves (this will allow the connectors to slide freely along the wires before you finalize the connection) before squeezing the tap connectors with the pliers! You only need two telephone wires out of four available in the telephone cord. These two wires are supposed to come to two middle contacts on RJ45. Please use the diagram below. It assumes you are looking on the RJ45 connector from the bottom (clip is away from you).
<a href="http://pictureposter.audiworld.com/47928/rd-wiring.jpg"><img src="http://pictureposter.audiworld.com/47928/rd-wiring.t.jpg"></a>
Click on the image to get a bigger picture...
5th step. Re-connect the mirror wire connector, switch on the ignition and check with voltmeter polarity of the power on the RJ45 connector. It should be exactly the same as polarity on the RJ45 at the end of the cigarette lighter power cord. If everything looks all right, connect the RD and check if it has power.
6th step. Switch the ignition back off. Tuck the "Telephone Wire Tap Connectors" into the wider part of the mirror base. Clip the mirror connector back.
7th step. Cut a small grove in the corner of the mirror wire cover depending which side you want the RD wire to exit to. I did it on the driver's side since the RD's in all my cars are attached via suction cups right above the mirror on the driver's side.
8th step - Re-clip the mirror wire cover.
9th step. Attach the detector to the windshield and plug RJ45 into it.
You are done!
For those who is wondering why I did not use any additional in-line fuse - the wires to the mirror draw power through the existing low current fuse already and there is no room for additional fuse in the mirror base.
You are done!
Frankly speaking the whole process is not that cumbersome to warrant the picture gallery. The most difficult part when I tried it first time was to find the correct wires in the harness to obtain switched +12V and the ground. Knowing which wires to use - the rest is a breeze...
RostyVyg
14
06-19-2004 04:36 PM
RostyVyg
03-04-2004 02:41 PM
RostyVyg
03-04-2004 01:11 PM
