Stratmosphere catback pipes
New S4 owner with a dumb question:
Are the two items below related or seperate? meaning do you guys all put both on the car or is one better then the other? I need a S4 exhaust education here. thanks.
Milltek Audi S4 2004 Dual Stainless Steel Cat-back Exhaust (RESONATED, has center mufflers) [pictured above] $1095.
and
Milltek S4 Hiflow Cats and Downpipes for 2004-on 6-Speed $1995
and
going to run them into the stock exhaust, but you can put the exhaust on without adding the dp's.
dp's change the cats and downpipe, which depending on your state may be smog legal or not (i don't think anyone has CARB certification) for dp's and highflow cats.
i think miltek is claiming around 20 hp for each, so a total of 40 hp or so.
The downpipes are the part that connects the headers which exit the engine to the muffler assembly designed to dampen the sound of the exiting exhaust of the car. The downpipes house the catalytic converters and has the O2 sensors. you can just do the cat back, which will get you a small gain, and better sound or add the down pipes for more power and a slightly louder sound. Hope that helps a little
even thought the second O2 sensor in our cars is really a check for the 1st one, they still have a spot for it. I have been scanning the car every night, no faults yet so.....
The 2nd O2 sensor sits behind the secondary cat in our cars. Once you put the Miltek's on they sit in part of the straight pipe.
BackseatLoverGirl
23
07-23-2005 11:46 AM
Are there any downpipes that are full 3" front to back? why is it they taper of to 2.5" in most kits
vwaudidriver
21
09-14-2004 07:14 PM
Dangler {/KAWF} BUMP
13
08-31-2001 01:04 PM
