Sunglass Holder Door Stuck Shut
The display and controls for an Escort 9500ci are installed in the sunglass holder on my '04 S4 Cab,m and the door is stuck shut. Has this happened to anyone and any ideas on how to get it open?
Failing that, you can also just remove the whole assembly. I am going to write up the technique I used to install mine without damaging anything later, but the key was buying two small spackle spreaders from Home Depot for $0.65 each and using them in tandem to wedge down the tabs on the inner upper surface. You may also be able to use a few old credit cards, but I think the raised lettering would mar a surface or two. If you have supermarket discount cards, gift cards, really any plastic card with no raised numerals, you can force them over the tabs (you will need 3, two to unlock and one as a tool) and then you can pry the whole thing out with a screwdriver or the third card.
