Are there any stereo improvements from stock that you can go back after your lease is up?
#14
Ah. Piece of cake. Go here.
Plug in the speaker values (4 ohm in this case) and the desired crossover value. The calculator will give you a cap value to use. To keep things simple I took the calculated cap value then found a value that was close among those offered at the electronics store I went to.
Use the First Order calculator for Two Way Networks. You can use 2nd Order but the cut rate may be too aggressive to blend well.<ul><li><a href="http://www.mhsoft.nl/spk_calc.asp">Crossover calculators</a></li></ul>
xkahn
02-08-2018 10:43 AM
striders
Q5/SQ5 MKI (8R) Discussion
11
09-05-2015 06:01 PM
