S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Tire choice - down to 4 - which set to choose? Will 245's rub?
Old 07-09-2008, 12:21 PM
  #21
AudiWorld Uber User
Tgr_Clw's Avatar
Agree.
Old 07-09-2008, 01:53 PM
  #22
New Member
kdj916's Avatar
Default Do most of you disregard the 95Y XL load rating recommendation?
I went with the BF GoodRich KDW's to try and stay with the XL load requirement.
Old 07-09-2008, 02:23 PM
  #23
Corrado79's Avatar
The 95 yes, the XL no. As long as it's XL, you should be fine. 95 is unnecessary.
Old 07-09-2008, 02:25 PM
  #24
Corrado79's Avatar
T1R's are terrible. Just got done with a set. Dreadful.
Old 07-09-2008, 02:55 PM
  #25
AJG
AJG's Avatar
I like my R888s. But, they are noisy.
Old 07-09-2008, 03:21 PM
  #26
Member
B6SilverS4's Avatar
Default why not dunlop direzza star z1
They are very good and fits what you desire.
Old 07-09-2008, 05:02 PM
  #27
New Member
kdj916's Avatar
Default Your response confused me, so I went to Tire Rack to research the issue...
Boiled down in simplest terms:
1. Tires with XL ratings are reinforced to withstand higher load pressures (For P-metric tires 41 p.s.i) - My assumption is that an extremely heavy (awd- front tires supporting a 4.2L engine) car at high speeds would tend to heat up with a corresponding pressure increase.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=55
2. The 95 in 95Y refers to the load rating that the tire is designed to handle (95=1521 lbs - by extension 4x1521 lbs = 6,084 lbs of gross vehicle weight, which does in fact seem excessive for a car that weighs 3,925 lbs). As probably everyone but myself knew already, Y refers to tires designed to exceed 186 mph. Every recommended tire on Tire Racks site for a 2004 S4 was a 95 load rated tire. I would assume that this builds a margin of safety for how front loaded our cars appear to be.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=35
Old 07-10-2008, 05:43 AM
  #28
TEB
TEB's Avatar
Default Any reason Michelin PS2's are not on your list?
Definitely the best tires I've owned.
Also look at the BFG g-Force KDW.
Old 07-10-2008, 09:51 AM
  #29
Fluffhead's Avatar
Goodyear Eagle F1
Audi Advocate
Wheels & Tires Discussion
07-15-2008 09:08 AM
eldoj
06-10-2008 07:49 AM
HarnessedLunacy
28
03-10-2006 04:31 AM
kaiserwilhelmi
9
01-15-2006 06:38 AM
NogaroGO!
9
12-12-2004 03:55 PM
Quick Reply: Tire choice - down to 4 - which set to choose? Will 245's rub?
