Torn Bushings; Upper Control Arm
great.
Under waranty, dealer ordered all four bushings. I'll go with stock for now, until I'm out of waranty, in which case, polyurethane here I come.
also make sure they are tightening the bolts for those bushings when the suspension is at resting load. If they are tightened while the suspension is hanging free it will stress them at normal resting height and even more when the suspension is compressed. They will tear faster.
they make noise and it gets annoying. THere is not enough flex so they need to slide in the metal sleeve... the lube dries out and they squeak.
K-Mac has poly bushings with camber adjustment, those are the only ones I know of. I had them on my A4 for 2 years.
I drive the car pretty hard. Couldn't tell you if the Ohlins were the result of it, but the dealer doesn't seem to think so. These bushings are a common failure point, as I've seen the bushings tear across the model lineup.
