What factor for drivetrain loss should be used to calculate flywheel hp?
#11
The problem is...
The conditons vary so much.
What was ambient temp? Barometric pressure? Elevation? Was the cooling fan in front of your car big enough to be effective? Was the dyno in calibration? What kind of fuel?
You can't assume your car was making 340 when you did the runs and just blindly use a correction factor to back into 340hp. Maybe conditions that day were such that you were making less than advertised. At that point, all your numbers are fubar.
#13
well yea but...
AWE has dynoed 4 B6 S4's which all got within 1hp of each other. they havent done nearly enough to get a real number yet. Also unless someone pulls there engine and does an engine dyno and chasis dyno we will never really know. Its all just guesstimates. Hence why we really need to look at gains over base not a bogus conversion factor.
Chaka
26
02-04-2003 09:20 AM
MasterB
Performance and Tuning
10-09-2002 11:02 AM
audi, b6, calculate, calculating, drivetrain, drivetrains, drivetrin, factor, find, flywheel, hp, loss, s4
