what size torx bit for brake change??
I was going to change my front brakes yesterday but I didnt have any torx bits to my disposal, what size do they used to change the front brakes?
thanks
also it is the same size in the rear also?
thanks
You need a allen bit and it's 8mm IIRC
The large torx hold the carrier to the hub, you don't need to undo that. The ones you want are on the caliper sliding pins under the rubber boot.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
