whats teh best way to clear snow off your car without scratching it?
#11
It pollutes the environment so you have to be able to recuperate and recycle the product and it is very expensive...
It's aircraft de-icing fluid sprayed at 160 degrees F.
Yes I know, it's a bad joke.
<img src="http://pictureposter.audiworld.com/46874/deice.jpg">
#12
get a snow brush and clear off the top layer of snow. I would leave the rest on the car.(dont brush it to the metal). The engine heat will clear the hood...and the rest will blow off. I would also give the car a good waxing if you can. Happy shoveling you all!
#13
If you have a heated garage, though .. your car shouldn't be getting snowed on overnight.
#14
<ul><li><a href="http://www.griotsgarage.com/catalog.jsp?L1=L1_1000&L2=L2_1003&SKU=8215 4">http://www.griotsgarage.com/catalog.jsp?L1=L1_1000&L2=L2_1003&SKU=8215 4</a</li></ul>
#16
... I turn on the car, turn on the heater, let the car exterior warm up and melt a thin layer between the snow and metal and slide it all off with a brush. Seemed to work ok...
#18
I know there are other vendors with a similar product that I cannot find at this time.
My car is garaged and if it gets snowy at work, I use the same process as others mentioned of sweeping most, but not all, of the snow off using a conventional snow brush, leaving a thin layer of snow on the car that will melt once I get home.
it is a compromise of my preventing being a road hazard with blowing snow and scratching the paint.
This thing seems like a good idea and I thought about buying one a few years ago, but never did. I know the local Volvo dealership uses them as they had several in the shop area one day when I was there not long ago<ul><li><a href="http://www.amazon.com/gp/product/B0006H4B0M/ref=ase_onlinetoyst08-20/103-0047259-8940669?s=automotive&v=glance&n=553294& ;tagActionCode=onlinetoyst08-20">http://www.amazon.com/gp/product/B0006H4B0M/ref=ase_onlinetoyst08-20/
#19
The material itself might not scratch the paint, but unless the surface of your paint is clean, it will drag the dirt, sand and salt across your paint, which will result in swirls/scratches.
For anything less than 4", a regular snow brush is fine. Over and above that, this tool is the ticket, but I wouldn't drag either across the paint if you're at all concerned about swirling and scratching the finish.
