wheel advise
<center><img src="http://pictureposter.audiworld.com/120159/gt1b_l.1.jpg"></center><p>I have few question about wheels! Anyone ever heard about MRR GT1 ? Can I use 19"x8.5 in the front and 19"x9.5 in the rear ? Tire size 235/35/19 in the front and 245/35/19 in the rear? That will be fine with OEM suspension or prefer to chage it ?
(2005.5 S4)
Thanks !
(2005.5 S4)
Thanks !
and it looks like the 8.5 and 9.5 have the same offset so you would probably have to go with different tires. If it were possible to get them in the same width with different offsets you could theoretically get a staggered look and still use the same size tires. I also think you may have problems with 9.5's in the front, its pushing it.
<center><img src="http://pictureposter.audiworld.com/79951/a4_cab..jpg"></center><p>the tires where 235/35/19F and 265.30/19R.
but why would'nt you just go 9.5" all around? Staggering is not necessary in an AWD car, unless you cannot fit the same width tire in the front as you can the back.
<ul><li><a href="https://forums.audiworld.com/s4b7/msgs/50871.phtml">https://forums.audiworld.com/s4b7/msgs/50871.phtml</a</li></ul>
