Who here has a cordless impact wrench..
I break the bolt w/ torque wrench and then use a 18v Dewalt with 10" ext w/ deep socket...
... to remount, I use the dewalt which torques them to ~75lbs then drop the car, and finish off with the torque wrench.
I have a stud kit which makes it light years easier.
I know the torque wrench shouldn't be used to break the bolts, but that's just the type of guy I am. Plain crazy.
I also use one - awesome
It makes changing wheels so fast. I use a breaker bar to loosen the lug nuts and then the cordless impact wrench to take off the lugs. I also use the cordless to put the lugs back on. I have one of the cheapest Dewalt models (9.6V I think) since the cheap ones are the only models to tighten to less then 90 ft/lbs (don't want to over torque to wheels). As I recall, it tightens the lugs to around 83 ft/lbs and then I give them a 1/4 twist to 90ft/lbs with the torque wrench. It comes with two batteries and a one hour charger. one battery will change wheels about 4 times before it nees charging. I can never go back to the manual method. Even my wife loves it because I spend less time in the garage. It was about $200 well spent.
I can't justify the expense at this point, myself...
I use a breaker bar... don't need to worry about running out of charge, etc. It doesn't take much to loosen the bolts.
One of these days I might get one, though, so I'm interested in hearing opinions.
-JPC
-JPC
I have one, best tool I own
I have a Snap-On 1/2 drive 18v impact. It lasts long enough to remove more wheels than I care to do in one day. And if I remember the number correctly it has about 285lb. ft. of torque. More than you will ever need for any lug nut
I've got a cheapie one from Harbor Freight that works just fine...
I wrestled with the idea of whether or not it was worth getting one as it's just another thing to pack as well as make sure it's charged. But I'm glad I got it as it dispatches with the lugs pretty easily. Like everyone else, I break the lugs loose first and then take them off with the impact wrench. I picked it up on sale for $29.99 at Harbor Freight, and at that amount it's not a big deal if it gets a little worn out from road trips or worse yet, lost or stolen. It's got a good amount of torque but the socket extension doesn't stay seated and will fall off (hey, like I said it's cheap). But the battery has held up for a while on a single charge after several wheel changes as well as helping Deeno with his wheel swap at Fernley.
<a href="http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90798">Harbor Freight Link</a>
<img src="http://pictureposter.audiworld.com/43280/impact-wrench.jpg">
DEWALT DW059K-2 18-Volt 1/2-inch Cordless Impact Wrench Kit on sale at Amazon
There was previously an additional $50 off code (THCAT5X6DEAL), but it appears to have expired.
Andrew<ul><li><a href="http://www.amazon.com/exec/obidos/tg/detail/-/B0001LQLE2/qid=1121785396/sr=8-1/ref=pd_bbs_1/002-1665735-2611225?v=glance&s=hi&n=507846">http://www.amazon.com/exec/obidos/tg/detail/-/B0001LQLE2/qid=1121785396/sr=8-1/ref=pd_bbs
ryobi from home depot, ($49 on sale)
I picked up a ryobi on sale. I already had the other ryobi tools, so I didn't need to buy batteries or a charger.
It tops out at 82 ft/pounds, so i don't have to worry about over torquing. It won't break the buts free either, but that's fine. It does make tire changes quick.
Take my advice: don't ever use the impact wrench to start the lugs. It mostly works, but it got me a stripped lug hole on one hub....<ul><li><a href="http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?CNTTYPE=PROD_META&CNTKEY=misc%2fsea rchResults.jsp&BV_SessionID=@@@@1580546948.112 1834913@@@@&BV_EngineID=ccefaddfekjgghdcgelcef fdfgidgmk.0&MID=9876">http:
NYCa4
Wheels & Tires Discussion
9
03-25-2003 11:40 AM
NYCa4
03-21-2003 01:21 PM
Poe
05-14-2001 04:55 PM
ex-quattro PETE
03-05-2001 10:50 AM
AIRFORCE3
10-10-2000 12:25 PM
