Will a 245/35/19 falken 452 rub on a 19x8 et 42 wheel on a S4?
Not sure if I should go with a 245 or 235. Tire Rack recommends a 245/35/19 which should be about 0.2 inches taller than the OEM 235/40/18. Probably not enough to make a difference. Others recommend a 235/35/19. I wouldn't mind having a slightly wider tire to protect the rim a little more. I had a set of falken ziex 512 on my 18s and they were narrower that other comperably sized tires. Any inputs? Thanks....
Re: Will a 245/35/19 falken 452 rub on a 19x8 et 42 wheel on a S4?
Sounds like it should clear fine...the offset would be saving you in this case. I had 245/35/19 with 35 offset and it was unbearable...had to switch to 235s. Those extra mm of offset should make it ok though...i think.
Re: not sure if this helps but 245/40/18 on the stock rims 18x8 ET35 required 3mm spacers
I'm confused, the stock 18x8 rims are a 45mm offset. Where were you rubbing? ON the strut or on the outside of the tire on the fender?
audiringpwr
07-31-2006 06:14 PM
Brooklyn
06-25-2006 04:34 PM
qtrofil
12-02-2005 08:22 AM
