WTF, is wrong with this freaking car!
I just went outide to move the car into the garage and my instrument cluster told me I have a right tail light out, again!
I just changed that bulb about a 1.5 ago. I have done nothing in the past month and a half but change bulbs all over this car.
I've had the car since it was brand new and up until then none of the bulbs blew. But now I can't stop them from going out.
Do we know what could be causing this in our cars?
I've had to replace 1 brake light bulb in each of my B6s and am aware of a few B7s with similar stories. In each case it seems to be the right hand rear bulb..
Given the small cost of the bulbs and the fact it only takes 5 minutes I don't mind doing it every other year.. ; - )
in the past 2 months I've had to replace my both rear tail lamps, license plate bulbs, last week I replaced my city light bulb. Now tonight my right rear tail lamp is out again, which I just changed 2 months ago.
Is the bulb "no good" or are you getting a false reading? Check out the bulb, go from there.
Clean(zero residue contact cleaner)and rebend (tiny bit)the center(+)bulb contact with lights off.
Dirty or poor contacts can cause early bulb failure.
Takes 2 seconds to do when you change a bulb next.
