17" winter rim update
Last year, Gary from Tire Rack posted a number of 17" rims that TR had test fitted with success. The wheel weights that TR used to make the 17" rims fit (clear the front calipers) are low-profile (3.5 mm high) and in most cases that meant 1.5 mm or less clearance between the wheel weights and calipers. Due to the EPA's ban on lead wheel weights, TR has been unable to source non-lead weights that are as equally low profile. For us Canadians, TR can ship non-balanced wheels and we could get the balancing done locally, however, this would assume that your local shop uses or could source the same weights that TR used, and that the same lead ban would not come into effect here.
while I prefer the higher sidewall of 17" rims, it seems that there are too many unknowns at this point, so I will go with 225/45/18s.
I'm with Bruce. I just picked up a set of winters in the stock 18" size. I understand the concept of a narrower tire but not convinced this really applies to a vehicle (as much) that rides so low to the ground. In a suv with 8 inches of ground clearance that is plowing parking lots with 2 feet of snow makes sense. Our cars ride so low to the ground I don't think a narrower, higher sidewalk tire in a 17" size will make much difference in that kinda of snow.
If u siding have to consider caliper clearance, lead weights, low profile weights, etc I'd say go for it.
To me the benefits don't out weigh the potential complications.
Not to mention the vehicle was designed to run a bigger tire and I'm sure there are performance shortfalls and most likely giving up a level of safety with the smaller tire.
Just my thoughts.
Just my thoughts.
I just ordered a pair of these 17" wheels for the S4: Hartmann HRS6 - 172 HC 17"
Looks like the fit is going to be really close. I agree that the 17" or these wheels in general are not going to look good at all. However it seems they don't make 'real snow tires' in the 18" S4 size. The majority of the 18" snows are "performance winter tires."
I need real snow tires, as we spend the winters driving back/forth to Vermont every weekend, for snowboarding.
Will post some pics when they arrive to show brake clearance.
In Canada there might be some 18's From Nokian??? Just a guess.
Considering trying out the X-ice this year. Much cheaper and easier to get in the States.
And to the earlier poster questioning why anyone would be %&*!!ing around with 17" wheels on their S4, I completely agree.
Do you know what -40 feels like? How much compliance do shocks/struts have at that temperature? None. At that temperature the extra sidewall is nice because the tire provides the give that the suspension can't. Just b/c 18" winter tires work well in your area doesn't mean they work well for everyone.
