2011 S4 and excessive Oil Consumption
#11
I have used a similar technique for the past 15 yrs and NONE of my cars have used any appreciable amount of oil. ALL cars will consume small amounts of oil. The info on Motoman is derived from use on motorcycles. But the same break in priciples apply to just about any internal combustion engine. MCs do not have Alusil cylinder walls like our Audis. Alusil takes longer for the piston rings to seat because it is harder. I always encourage anyone who has used this technique or similar to chime in if they have had engine issue . No one ever has reported any. It just works. I have recieved nothing but thank yous form those who have used the technique.
#12
Banned
Here's the technique that I use on the street. CAR MUST FIRST BE UP TO NORMAL OPERATING TEMPS. From day #1, accelerate the car Wide Open Throttle to the redline(just short of the redline for the squeamish.)I assure you that nothing unusual will happen if you go to the redline. After reaching the redline, let off the accelerator and allow the car to coast back in gear to normal operating rpms without using the brake(engine braking). Do not do this from a standing stop as in a drag race. Any gear is fine but lower gears will get the job done at a lower speeds. Do not do back to back WOTS. 3-4 times a day at the most. WOTS below the redline in any gear as desired are fine. But the engine braking is the most important factor. When you reach 1000 miles anything goes. Do not beat the car. But even worse is babying the car. BTW, the engine is not broken in at the factory, but it is run up to the redline on a dyno type machine.
#14
#16
This is my second Audi (2008 A4 2.0T and 2010 B8 S4). The A4 needed about a 1/2 qt after 10K miles. That seems fine to me.
My S4 needed nothing for the 1st 5K and I'm 3K into the next 10K with nothing needed.
I've had at least 8 other new cars that I kept for lots of years and never did anything for break in but what the owner's manual recommended (and sometimes not even that) and never had a problem with oil use. I will say that one car was a Ford tempo POS that had a rear main seal leak and dripped lots of oil into my driveway :-)
#17
http://store.blackforestindustries.c...yoil5w1li.html
That price is comparable to Mobile 1.
#19
Oil consumption depends on a lot of things; climate, driving style, etc. I have over 7K miles on my S4 and have had the engine oil warning come up on my MMI twice. The first time I dutifully drove to the dealership and had them top it off. The second time (2 weeks ago) I threw in half a quart of Shell "Clean Engine Formula" 5W 30 that I had laying around as I had other things I had to deal with at the moment. But, I bought a quart of Penzoil synthetic 5W 40 for the next "oil emergency."
I have an appointment to take my car in this weekend to look at the treadwear on my tires (since they didn't rotate them @ 5K service because of the tire plugs) and I'll have them top off the oil again.
But, having driven Audis for 20 years, I've learned that Audis burn a bit of oil - particularly when they're driven hard. There always seems to be some gasket or seal that's gone bad, and is leaking, or whatever.
Now, that doesn't mean you should purposely drive around with low oil or the wrong oil! Today's car engines are built to finer and finer tolerances to cope with the ever increasing demands place on them. It's even worse with a contemporary supercharged engine - which must deal with higher temperatures & pressures than the norm - so keep your oil topped off when at all possible!
