2011 S4 S-Tronic Dyno baseline runs-Dynapack Dyno
Video here: http://www.youtube.com/watch?v=XMQcf89iaHU
Runs were made on a Dynapack Dyno. Thanks Road Race Engineering for letting me use your dyno whom was my Evo tuner for the past 5 years: www.roadraceengineering.com
Please don't compare these charts to runs on other dyno's since every dyno reads differently such as: Dynojet, Mustang, Dyno Dynamics, Dynamite, etc...
63 degrees in dyno room running on California's finest 91 octane fuel...
Ya the dyno charts say 370z, but the shop just overwrote the files car that was on the dyno before my car and they didn't save the file name when they were doing screenshots. So, if you read Modified Magazine, you'll see a red 370z Nismo package featured in it in an upcoming issue. That was the car running prior to mine.
![](https://lh4.googleusercontent.com/_G-TRXba-d6Q/TWSb7S7utDI/AAAAAAAADEc/26gT1tD8iUg/Dyno%20001.JPG)
![](https://lh5.googleusercontent.com/_G-TRXba-d6Q/TWSb-_Ult_I/AAAAAAAADFU/jnHd7EDJGNI/Dyno%20005.JPG)
![](https://lh4.googleusercontent.com/_G-TRXba-d6Q/TWScPy5ottI/AAAAAAAADFQ/so2wTTQmcYA/Dyno%20004.JPG)
![](https://lh6.googleusercontent.com/_G-TRXba-d6Q/TWSb_R9gF5I/AAAAAAAADFY/9uXptxanZpA/Dyno%20015.JPG)
![](https://lh4.googleusercontent.com/_G-TRXba-d6Q/TWSb8Yt6D8I/AAAAAAAADEk/AT-sXUefcv4/308hp.jpg)
Torque vs AFR's. Wow, AFR's are a LOT leaner than what i'm accustomed to seeing in normal fuel injection cars. I guess this is the benefits of direct injection. Anyone care to guess why when my on the purple lines went rich that power spiked dramatically? What is the ECU doing?
![](https://lh6.googleusercontent.com/_G-TRXba-d6Q/TWSb88oWYCI/AAAAAAAADEs/2sODuKfGdEA/308hp-afr.jpg)
![](https://lh6.googleusercontent.com/_G-TRXba-d6Q/TWSb9d7E0QI/AAAAAAAADEw/Y_kzNBhBj6E/308hp-chart.jpg)
![](https://lh5.googleusercontent.com/_G-TRXba-d6Q/TWSb9_xNPsI/AAAAAAAADE4/kb3HC1oUbAc/308hp-chart-dark.jpg)
Torque Split graph
Torque Split graph
![](https://lh4.googleusercontent.com/_G-TRXba-d6Q/TWSb7yboEyI/AAAAAAAADEg/0wL6YQlMQu0/torque%20split.jpg)
Good numbers, and good idea to get a baseline. Looks like having it on the Dynapack gave it a Sport Diff error? I saw the yellow outline of the drive system at the top of the DIS, if I remember, this is what showed when I had the one Sport Diff fault I incurred.
On a side note - I personlly wouldn't leave tools on the Dynapacks while doing anything to a car - you can see items up there vibrating, there is really no need to leave things there and it's only asking for an accident.
I also wanted to put it on the dyno to stress the engine to see if it holds up well under heavy loads without it knocking too badly. So, now i'm confident that my engine is decent and now let the mod'ing begin.
http://www.audizine.com/forum/showth...en-S4-amp-335i
![](http://vwong.net/images/temp/b8-baseline-dyno.jpg)
Getting too hot is my assessment. The ECU will dump much excess fuel in when the engine is very hot (not a lot of cooling in a dead end dyno shop, the car is thinking at 100+MPH to have that kind of wind blowing by the engine and radiators). This excess fuel evaporates from the heat and cools the cylinders.
However, when the AF ratio become very rich, you should lose power. The only reason I can think of as to why the opposite is happening, is perhaps because when the cylinder temps go down, the ECU is advancing the ignition timing, giving you more power.
Thanks for sharing your data.
