2013 s4 dual clutch issue!
#11
#12
#13
I was also typically in Dynamic/Sport mode when this occured. I dont ever recall it happening in Auto mode, but then again, now that I think of it, why would anyone stomp on the throttle w/o being in Dynamic/sport mode? So its possible I could have reproduced it in Auto mode but I am usually crusing on the highway in Auto mode
#14
Jerking Issue
I showed the video to my f who has a 2010 b8 s4. He said he had the similar issue. The tech told him that for b8 s4, the system learns how the driver drives for last 5 times. If the driver usually drives the car gently and suddenly pushes the gas bar hard, the system will get confused and "cut off the gas" to stop to car for preventing accidents. That is the terms that the tech used to describe it. And this issue needs an ECU reset. Then it will be ok. However, the driver should keep revving the car hard and let the system know that is the way how the driver drives to avoid the similar issue occurs again. Otherwise, another ECU reset is needed except the driver doesnt rev the car hard anymore which is impossible for all s4 owners. Agree?
Now, I guess an ECU reset is a must temporarily but from now on, I really dont know how to deal with it. Anyone has come out with a final solution to end this nightmare?
Again, I really thank members for trying to help here.
#15
Rather than freaking out about it, why not drive the car a bit more to better understand how the DSG operates under a wide range of conditions? It's not a traditional automatic transmission, nor a traditional manual, so it doesn't behave the way those do...
#16
While there have been a few instances of real problems with DSG units (mostly the mechatronics unit), it seems that you simply may not have yet become accustomed to the DSG's responses.
#17
I dont know what the problem is. I visited the dealer last thursday and couldnt replicate the issue to them. They did the diagnostic test on it and found no problem at all.
Here are the links of two videos made at different time. Any clues?
It happened when I did launch control in dynamic mode. The issue just came randomly. And it happened in comfort mode as well or even happened when I accelerate with full throttle both in esp on and off.
http://www.youtube.com/watch?v=_JPAj...ature=youtu.be
Thank you.
#18
From what I can see in the video clip, you have not actually activated launch control. It appears to me that your stability control is still on, because I can hear what sounds like the engine straining against the brakes in the initial launch. Since the transmission is a dual-clutch automated manual, when in launch control mode there's no straining of the engine against the brakes at all. The engine simply revs cleanly and with no load to 3200-ish RPM, and when you let off the brake, it feels as if the car has been rear-ended. The initial movement off the line is much more dramatic and quicker than what I see in your clip. There is also a brief delay after releasing the brake before the car starts to move - again something that I don't see in your clip.
For launch control to be activated, if your car has ADS, you MUST be in "Dynamic" mode, and you must have completely deactivated the stablity control. This requires holding down the ESP button for about 5 seconds until "Warning-restricted stability!" appears in the center driver's information display.
Try again using these tips and see how that works for you.
#19
And I wanna mention it again. This issue not only comes during the launch control but also when I floor it with the ESP off. I will hold down the ESP for at least 5 seconds and try to floor it again.
Thank you very much.
#20
Again, thank you.
