2014 Driver Assist Package (ordering question)
#11
The adaptive cruise control is nice and it also include Brake Guard. I've had this feature on several cars but Audi needs to work on the implementation of it. I've had Brake Guard trigger several times for no reason (one time it decided to slam on the brakes while I was driving on the highway with no one in front of me, thankfully there was no one behind me either). Also the adaptive cruise control doesn't always work. I've approached stopped traffic and have to hit the brakes myself because the ACC didn't detect any cars in front of me.
#12
#13
Audi improved ACC and BG in 2013 models (curious, what is your MY?), I have been using both systems for a year now and never had any issues. Brake Guard probably prevented me from rear ending a car that unexpectedly stopped in front of me while I was checking my blind spot. However note that the system only tracks moving cars that stop or slow down, not stationary objects!
I had an Infiniti G37 with ACC previously (it was laser as opposed to radar based) and I never had any problems with it.
#14
It's a 2013 model. I've also noticed that the side assist stops working sometimes in heavy rain after about 20 - 30 minutes of driving. The ACC sometimes works with stationary traffic, but not always. It also seems to have issues if I'm driving up or down a slight incline and there are cars in front of me.
I'm not sure if you meant the ACC or the Side Assist in your rain comment. While I've never had it occur in either, I suppose if the rain was heavy enough, the ACC or Side Assist radar beams could be disrupted. I've also never experienced the incline issue described so long as the car in front was already detected as moving previously.
As a side note, after the ACC stops the car due to a following car in front coming to a stop, the car will not immediately move on it's own unless you tap on the accelerator
#15
That makes sense, the Side Assist sensors are located low in the rear bumper and they will be inside the thick mist created by the tires in heavy rain. I read somewhere that SA uses low power radar in the 6Ghz frequency range so it will be affected by the presence of liquid water in the air.
#16
From the manual: "The ACC only reacts to objects that are moving or has already been detected as moving. In other words, if a vehicle which has already been detected by the ACC, turns or changes lanes and another stationary vehicle is located in front of that vehicle, the system will not react to the stationary vehicle". This would also occur if you came upon stationary, stopped traffic when, since you were far enough back, hadn't been following an ACC detected car previously.
The ACC only works at speed above 15 mph (or something like that). I think the A6 and above work all the way down to 0 mph.
#17
When you say ACC sometimes doesn't work in stop and go traffic, exactly what do you mean? What doesn't it do that you believe it should?
Jay-S8
18
05-07-2021 12:50 PM
mkirkpatrick
Wheels & Tires Discussion
09-03-2015 08:31 AM
Touge.ca
Canadian Discussion
09-02-2015 01:28 AM
