All my vagcoms have disappeared!
I had my Stronic flashed yesterday as I had an issue. Anyway, all my efforts, research etc. for the mods I made via vagcom disappeared. Now I am back to the wink when the signal is on etc. Anyway it looks like any time there is a flash the car is set back to the factory settings. Would the APR tune be affected as well with a similar flash?
We need input from someone like NWS4guy on the VAG COM questions.
But it sounds to me like they might have flashed more than just the CPU for the DSG. I thought all VAG COM's ( or at least most of them ) were stored in the main CPU. I don't know why the CPU for the DSG would store something like disabling the winking DRL's...or VIM, efficiency mode, etc.
Sorry you lost the VAG COM's. I keep a copy of everything I've done in writing (print off the instructions) so it can quickly be replicated.
There was speculation that some of the TCU updates also require the ECU to be flashed. If that is the case I am sure the APR tune will disappear and have to be sent back to them.
Seinsmeld13,
Any chance you can post what transmission software you are running now? Does the car feel/behave any different?
TIA
Seinsmeld13,
TIA
Seinsmeld13,
TIA
Seinsmeld13,
TIA
One quick way to restore the settings is to:
a) save the "before" and "after" long coding for each controller you modify (most of my VCDS changes are in 5 or 6 controllers).
b) when you get your car back, compare the reset long coding to your saved "before" coding (make sure the factory settings haven't changed)
c) if the factory coding didn't change, just replace the entire long code with the "after" code you had saved instead of having to make each change manually.
Yep, they will sometimes reset the factory settings to default when flashing the TCU just so they start with a clean slate and baseline, then the ECU relearns the DSG and driver characteristics. This SHOULD NOT be a reflash of the ECU, just a reset to defaults - that is not to say that they might not have reflashed the ECU, the shouldn't have, but still could have anyway.
Hal_TT::CBP
02-17-2004 07:59 PM
allroad'Ed now
Audi allroad
15
06-28-2003 05:48 AM
