Anyone Experience Their S-tronic Not Shifting Smoothly?
I've had my 2010 S4 with Prestige and ADS for 3 weeks now, and noticed that the S-tronic will intermittently NOT shift smoothly. It seems to happen about 25-50% of the time when taking-off from a stop at slow-to-medium speeds. It's not terrible, but I would have expected very smooth shifting when starting out slowly. It doesn't seem to matter how the ADS is set. I've never driven an all-wheel drive car or one with wide 19 inch wheels all around. I'm ready to take it in to see if anything is wrong. Is this normal for the S4? Thanks in advance for your feedback.
Best Regards, Hiker Guy
I have a 2010 s5 with tip auto it does the same thing at slw speeds seems like it starts off in a higher grear and then drops off to a lower grear I have seen somewhere on here that audi will remap the computer so when I take my car in for the 5k service I am going to ask the dealer that
I'm attributing some of that "abruptness" to the nature of the transmission. I've never felt like it was an inappropriate or worrisome up- or down-shift however.
I have only had my '10 S5 for 3 days, but I noticed that too, but it feels more like it is a fuel saving measure. Kind'a like when you start off in second gear w/ a manual trans instead of 1st.
I haven't noticed any rough shifts if the tip is in "s" mode. So thats why I chalk it upto the "d" mode trying to save gas.
I can foresee software upgrades for this box
@ Hiker Guy - it sounds as if yours is not quite right if it's happening in all ADS settings. Dealer trip!
Conversely, I sometimes experience overly aggressive shifts, almost uncomfortable jolts, when pottering around town, but only when the gearbox is in Dynamic mode. In all other settings it's very smooth.
I've noticed that if you start from a dead standstill in dynamic and don't feed it enough gas then it can struggle with shifting. You can baby it and it's fine, floor it and it's happy as a clam, but there's a zone somewhere inbetween that it seems a tad confused. Not really an issue since I'm generally driving in other modes, but I did encounted this while learning to handle the beast. I've also encountered a couple of times where there was a lag downshifting at higher speeds when you floor it, say at around 65 or 70 mph (?). I then double tapped the left paddle shifter before stomping on the gas and it worked fine. I would not call this a recurring issue, just an idiosyncricy/quirk that will likely get smoothed over with eventual software upgrades.
Yes I know, hence my use of the word "overly". Even allowing for the aggressive nature of the 'box in Dynamic mode, to which I'm well accustomed as I use it frequently, I get random very fierce shifts (at low speed and usually upshifting) which passengers have yelped at and which are too fierce and random to be correct intended characteristics of the setting.
