Anyone have pics of B8 S4 with H&R OE Sport Springs?
#21
I don't understand why swapping springs will wear out the dampers any quicker. A damper is essentially a piston in a bore and, unless it is slamming into the end of its travel, I don't understand why simply repositioning that piston in the bore will cause any faster wear.
Is this accelerated wear a fact, or a myth that has become a "fact" because people believe it to be true?
The way I look at it, start with springs, see if you even like the drop and harsher ride... (cheap at around $300) then if they fail (unlikely) or you want something more adjustable (likely), etc, "spring" for the more expensive coil overs. You'll now have coil overs with less miles on them! lol
There's nothing wrong with going straight to coil overs if you know the ones you want and you like how they feel... but in my experience, each brand is different, and they're not a cheap mod to be messing around with, so you should probably make sure you really like them.
To just buy a set of coil overs without riding in a car with them would be like buying one of the exhausts without hearing it. They're all quite a bit different.
#22
Hi
Is there anyone tried this KW adjustable spring kits??
I like that it can keep a bit of height flexibility while retaining drive select option.
http://www.kw-automotive.info/int/kw_suspensions.php
-The KW coilover spring kit is used for lowering the vehicle in combination with the serial dampers, even when electronic damper control is installed. This lowering solution from KW optimises the dynamic performance and the steering behaviour without the electronic damper control deactivated. For this solution vehicle specific adjustable spring seats with adjusted KW lowering springs and the matching elastomer as well as the dust cover system will be used. This complete conversion allows an individual adjustable lowering solution.
#23
Hi
Here's my dirty car on just H&R springs, after an alignment, etc of course.
![Name: IMG_0277.jpg
Size: 149.2 KB](https://www.audiworld.com/forums/attachments/s4-b8-platform-discussion-134/79569d1501280449-anyone-have-pics-b8-s4-h-r-oe-sport-springs-img_0277.jpg)
B742S4FTW
03-15-2015 10:20 AM
Audi Q5 H&R Sport Lowering Springs, $175
B742S4FTW
03-08-2015 11:44 AM
