APR 2+ - CLUTCH ISSUES???
#11
Banned
#12
I haven't had any issues with my stock clutch, and I don't necessarily think the stock clutch is horrible for stock or Stage I+. I do think there is a lot of inconsistency from the factory with our clutch setups. Between loose bolts, bad input seals, flywheels showing up out of spec, I think it's really luck of the draw. If you get a good clutch assembly, you may even be able to hold stage II power on it for a while. If you get a bad one, you may even have trouble with stock power.
#13
I think I remember reading a couple of threads where people have had the dealer look into the clutch and replace some of the parts (if not the whole assembly) of the clutch.
I would suspect depending on the dealership, there may be suspicion or resistance because warranty wouldn't cover wear-and-tear items. And depending on how you drive it, a clutch may fall in that category.
#14
My clutch has held up perfectly since this event, I have tested it in every scenario and it hasn't slipped at all. As long as I slip it for launches it is fine.
My advice would be just don't side step your clutch when you launch it. If you want to spin the wheels with a B8 S4, you cannot do it on dry pavement!!! You will fry your clutch if you do.
#15
Think I'll try another dealership and see if I can get it replaced.
#16
Man I would say that at low mileage if anything went wrong with the clutch a dealership would have difficulty proving misuse like riding the clutch or "sidestepping" it. I don't do either of those because a burning clutch smells terrible
and I don't have the $1500 or whatever to keep replacing them. Doesn't make sense being irresponsible with my 50K car.
#17
Banned
I think I would have no problem getting a new clutch under warranty if needed. My good friend is now Service Mgr at the dealership where he used to be GM and where I bought my car. Not everyone else could be so lucky. In fact, he picks my car up, leaves me his car, and takes my car in for service when it needs it.
#18
Here's how it looks on stock clutch on a stock B7 RS4 and tune/exhaust B7 S4 (with JHM's launch control which is built right into the tune for manual cars). No problem spinning all 4 tires.
www.youtube.com/watch?v=BoV0lB3g3kE
www.youtube.com/watch?v=8wdDGPDQ3QI
#20
I have done this a once or twice. One time I was trying to show off for my pops while pulling a U-Turn. Had it in high revs, wheels broke loose with no ESC (because of the turning), but after 1st gear, second just slipped. Reeked for an hour.
Full APR Stage II+ on a 2014 S4 with less than 4K miles. (6MT)
No real long term damage (hopefully), outside of some premature wear and tear. Seems like the clutch is now worn in or broken in, which likely would have taken a several months/miles.
Sucks. Live and learn.
As for warranty claims, In my B8 A5 I was stuck in a snow bank. I let a girl who said she knew how to drive a stick, drive it out while me and my buddy pushed. She rode the clutch till it damn near caught fire. It was smoking for hours.
Audi replaced the clutch and other parts free of charge.
JPRobertsons
06-20-2006 05:24 AM
