Audi 19" 5-arm hollow spoke (using Winter Tires)
I will be using Audi 19" 5-arm hollow spoke wheels (8k0071499) for winter. I have a second set.
Tires: Dunlop SP Winter Sport 3D
Should I use 235\45 19's or 245\40 19's (26.7" diameter) ?
I cant find the diameter for 235\45 19 on the 8.5" rims.
What's the largest diameter I can use with the 5-arm spoke wheels? I think the stock Conti Sport Contact 3's are 26" in diameter?
Will 26.7" rub?
Will 26.7" rub?
Try using this wheel/tire calculator. It should help you decide. One thing to keep in mind is that, overall, thinner is better for winter tires.
http://www.rimsntires.com/specs.jsp
Good luck.
Good luck.
Will winter 245\40 19 work with 5-Spoke Titanium wheels?
Good luck.
Good luck.
18 mm (2.7%) taller
Pilot® Alpin® PA3™
245\40 19's are .7" taller will they rub a stock cars?
wolfjo
08-19-2017 05:33 PM
03A627 2 04A842
10-18-2005 12:11 PM
