Audi clutches and their fault
#11
Can you explain this? I let off the gas in both conditions, so the amount of fuel being sent into the engine should be the same... I get an blank reading in the "instant fuel economy" under both conditions.... what's the science here? Now I could see that keeping it gear could reduce speed and save on brakes due to engine braking, but how exactly do you use less fuel?
#12
#13
Well I imagine the tachometer on these cars is a digital device controlled by the ECU. I suspect Audi tried to get cute and put some logic in their software to anticipate where the needle should be in response to inputs rather than simply displaying a real reading from the engine. There seem to be some bugs in the logic. On the DSG cars, if you floor it and cause the transmission to skip several gears on a downshift, sometimes the tach needle gets confused and bounces around like it's having a seizure. It clearly isn't reflecting the actual engine RPM in those cases.
#14
This might be due to the very quiet timing of the engine - when using a Gtech, it cannot pick up the RPMs from the cigarette lighter like it can in most cars - timing is very insulated.
#15
if ur coasting OUT OF GEAR with foot off the gas pedal, fuel is INJECTED to keep the engine running because the wheels are no longer turning the engine.
#16
hmm cant seem to be able to find the edit post button, so i'll add this here.
i forgot to mention that in senario 1, the cluth has to be out, cause if u push the clutch IN with the gear stick IN gear, ur estentially OUT OF GEAR.
#17
Thanks for your answers guys! I never knew that, it makes sense now that you've all explained it. Guess that's a bad habit...Feel kinda stupid here.
Well, I'm not buying this car for MPG anyways. I figure I take a 3-5 mpg hit down from my A3 which I average 23-24 in on a daily basis, but that's not a bad decrease considering the extra 125 hp I'm getting!
#19
No my clutch is new its just not as comfortable as others. its almost like BMWs and the Clutch delay valves they put on there cars. You would never know i hate my clutch lol cause i drive it smooth just takes more finessing on these cars than older clutches. I wonder does our car have a CDV?
And my clutch was bad before trust me it was all screwed they replaced whole clutch and flywheel under 3k miles im up to 4300k now and its much much better but still not the best clutch on the road.
Also I think clutches coupled with AWD in general take more finessing due to the more complicated drivetrain. they just feel different than lets say my 2004 350z clutch
#20
![Roll Eyes (Sarcastic)](https://www.audiworld.com/forums/images/smilies/rolleyes.gif)
