audio differences
#11
I agree the B&O sounds much better than the Logic7, even with the Logic7's EQ fully tweaked. I do wish the B&O had an adjustable EQ, but not a deal-breaker. It still sounds nice - the bass is a bit on the thin side, but that can be remedied pretty easily.
#12
Additionally with NAV, the single disc is DVD/CD player.
The Max capacity of the SDHC card to read is 32G formatted to FAT32
I have played back as high a resolution as lossless .wmv with no issues (though with wind and road noise, this is moot, I just stick to 192K
#13
A couple corrections below...
With nav you get single DVD, without, it's single CD
This can be enabled via VAGCOM
* You cannot rip from a CD to the internal hard drive. You can only import from an SD card.
#14
With B&O, bass is pretty much non-existent. Mid and high responses are pretty good for a car system. It could definitely use a powered subwoofer if you wanted to feel any real bass. But I already went through my booming system phase with my first car so I don't mind it much. I think after getting an aftermarket exhaust I'd mind even less.
#15
Also I forgot - with B&O you get dual SD card readers, this is nice, since when you put the cards on shuffle, it will not shuffle just a folder you start in but the entire card. This allows me to have different music imported to the Juke, and have 2 SD's so I can get many combos of what I want to listen to (as well as something for the family/wife on their own card).
#16
I agree on the B&O bass but I am not a bass person (in fact too much annoys me) so its not a big deal. Most of the time, my base is a little to the left, sometimes in the center but never ever turned up a bit. To me Bass ruins the crisp sound of the other instruments and too much basae to me is as bad as raking your nails on a chalkboard. Base vibration also tends to be more annoying to people outside the car than it is to ones inside the car but the ones inside the car dont know it
#17
If you want aftermarket amps/speakers, but OEM headunit, you should look at the various products from Audio Control to do so:
http://www.audiocontrol.com/t34/1761...tegration.html
I currently use the LC2i for my aftermatket sub amplifier i have. If i wanted aftermarket amps for the other speakers, I would have to go to their larger units which can accomodate up to 8 channels i believe and still have use of your OEM MMI.
Here's a short demo of how the LC2i works:
http://www.youtube.com/watch?v=rEoqLbgKNu0
Check it out at this link.
http://mobile.jlaudio.com/products_c...php?page_id=94
#18
>> surround, DSP and cabin monitoring cannot be enabled with VAGCOM - those are B&O specific features.
#19
#20
Hey thanks guys!
Well it looks like I'm outta luck. All my digital audio is in uncompressed broadcast wave format, because that's the format my recorder uses. I can convert these to .wav, and I generally record at 88KHz/24 bit (CD's are ripped at 44k/24b), but it doesn't look like the Audi system (regardless of whether the standard one or the B&O) reads and plays uncompressed .wav files at any resolution/sampling rate, is that correct?
Or is .wav considered a subset of .wma and it will read them?
On the DVD's, is that only DVD video or can it read DVDs as a data disc e.g. of .wma files or even DVD-A (audio)?
