S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Cheap netbook for vagcom...
Old 11-27-2011, 07:10 AM
RCM09's Avatar
Default Cheap netbook for vagcom...
Anybody using a netbook dedicated for using with vagcom. Thinking about getting one as I'm a Mac user. Just wondering how well they work with it? Seen some as low as 149.00.
Old 11-27-2011, 08:52 AM
sor
sor's Avatar
Originally Posted by RCM09
Anybody using a netbook dedicated for using with vagcom. Thinking about getting one as I'm a Mac user. Just wondering how well they work with it? Seem some as low as 149.00.
Just a warning, I've seen some newer netbooks on the low end with ARM processors, that run embedded windows. You won't be able to find much software to install on these, even though they look and run like a normal windows netbook at first glance. You may be better off doing a bootcamp install if you've got a macbook, probably less expensive also.
Old 11-27-2011, 11:16 AM
PsYkHoTiK's Avatar
If you plan on data logging, a laptop with a lot of horsepower is recommended (you can increase the sample size).
Old 11-27-2011, 05:26 PM
youS4's Avatar
I was lucky enough to snag one of these for $150 during Amazon's Black Friday Sale: http://www.amazon.com/dp/B004UR1670/ref=pe_175190_21431760_cs_sce_dp_1 Dual core & Windows 7 (albeit the "Starter" edition). I heard you could also hack this one to make it take 2GB RAM. Bought it just so I could comfortably use VAGCOM while in the car...and to carry around with me for general use. I have a 15" laptop right now, and let me tell you, it sucks using something that big & heavy in such a limited space. Plus, my old laptop is dying...parts of the screen are fading o_O
Old 11-27-2011, 06:43 PM
NWS4Guy's Avatar
That will work fine for any basic VCDS use, I have an older (3 years old) Acer Aspire One that I got off woot.com, you can easily expand these to 2G using a single 2G SODIMM for very cheap. This will work for all but what PsY said with high data logging rates, where it will likely choke.
Old 11-27-2011, 07:36 PM
skiracerblah's Avatar
i had a netbook before. They're agonizingly slow. Cough up a few more hundred for a real laptop.
Old 11-27-2011, 08:08 PM
helix139's Avatar
Take a look at the Alienware M11x. It's small but you can still get some significant power in them. Not terribly cheap, but can be had for well under a grand, especially if you look on the Dell Outlet.
Old 11-28-2011, 04:07 AM
IvanS4's Avatar
Agreed. Cyber Monday has at least 4 full-fledged laptops around $300 - do yourself a favor and get a device that will last a few years.
http://dealnews.com/
Old 11-28-2011, 06:59 AM
JohnBoyToo's Avatar
and too small for anything less than the best eyes
Gave the one I had away
Old 11-28-2011, 02:19 PM
socfan12's Avatar
I'm a MBP user as well. I believe some were successful running VagCom on their Macs using VMWare or Parallels? I plan to retire my ancient XP laptop (only used for VagCom at this point) and going this route.
Quick Reply: Cheap netbook for vagcom...
