Door Speakers 2013
#11
You'll need a very sophisticated multichannel audio processor in order to integrate properly with the factory amplifier to get all the audio and not lose content. It's not impossible, but it's a very complicated task to do right.
#12
Probably going to go this route so I can leave the H/U intact and basically make it a simple control unit.
http://www.sonicelectronix.com/item_...trol-DQXS.html
This will allow me to control frequency response as well as crossover points and time delay.
Coupled with this: http://pacificstereo.com/car-audio/c...ne-pdx-v9.html
And finally these (could not use these in my BMW and dying to put them back in service)
http://pacificstereo.com/car-audio/c...s-pro60se.html
http://pacificstereo.com/car-audio/c...s-pro50se.html
Now you can see why I want to find out the measurements as I currently have all this gear minus the processor.
It's simpler than using the Orban processors that radio stations use which will control attack and release times as well as a multitude of other things.
Still though, it looks like I have to retro engineer this in order to get the diameter and depth of the door mounts. The rear deck is easy as it uses a shallow depth (low profile) sub and I have a Boston Acoustics DVC 10" that will drop right in.
#13
No need to dump on people giving their opinion, even if it is not what you wanted to hear!
#14
Not really that difficult. I currently use a programmable processor now that is software driven to smooth out the sound curve as well as controlling time and phase.
#15
I'll be sure to tag your name and ignore all future posts then. If you have such a history in sound and come here for help perhaps you should pop a door panel off and borrow a tape measure.
Since people here readily change their exhaust, ECU, etc... I had no idea it would be such an affront to people's sensibilities to mod the sound system.
Simply trying to find a door size and people keep going off topic to the B and O system which I never commented on. You may notice the vehicle is on order or I would have.
#16
#17
I think you're missing some speakers there. Like the center channel in the dash, and the speakers in the rear deck. You're also assuming there are passive crossovers everywhere and no bi-amplification. That may or may not be true.
#20
Sometimes I spend upwards of two hours one way to work. Living in DC-Metro classified as some of the worst traffic in the US.
Honestly, it blows my mind that people here have no problem spend thousands of dollars and hours on vag-mods or exhausts, intakes, ecu flashes, etc... but mention changing a stereo and you are marked as a pariah.
Seriously, forget I asked. I'll figure it out myself when I get the car.
