Downshifting
Downshifting
After clocking only about 300 miles so far, I've received a number of messages indicating not to downshift above 1300 rpms. While I've been driving a manual for decades including my most recent A4, I often downshift to brake, not at ridiculously high rpms, but reasonable. Any insight on why this car prefers me not to do this practice? (1300 seems extremely low vs. 2500-3000 which seems more appropriate.)
Thank you
Thank you
Thank you
Thank you
I downshift above 1300rpm all the time as I use the gearing for breaking as well. What messages are you referring to? The shift indicator in the DIS shows the optimum gear for lowest fuel consumption but often it would frequently tell me to be two gears higher (5th when in 3rd) than where I like to operate the engine. It seemed so ridiculous at times that I turned it off. Is this what you're referring to?
I'm sure many have seen this screen and just don't comment, this screen will also tell you things like when to upshift and skip gears for economy, closing windows, turning off the A/C etc as well.
The efficiency program was not active (but is on the MMI) for 2010 models, so unless someone unlocked it with vag-com, they won't see it there anyway. It's one of about 5 screens you can display on the DIS between the speedo and tach, many people I have found either don't know you can show other screens and leave it where it's at from the dealer delivery, or choose a screen and leave it there - typically either Trip 1 or the large digital Speedo and never cycle.
There should be an option in the MMI to disable the shift suggestions, which display which gear your are in and will display an arrow with the suggested gear.
I keep mine on, though I usually ignore what it suggests unless if I want to get decent mileage out of my car
minman26
S4 (B8 Platform) Discussion
09-18-2015 03:08 PM
Dimitri
01-04-2000 03:14 AM
eddie
08-26-1999 08:43 PM
